________________________
Wire in '448' to the 'New Permissions' of the Access Rights VI. This will set the file as readable, writable and executable. I just tried this (on WinNT, though).
The 'permissions' parameter is a 16-bit integer where the least 9 bits are used. Of these, for Windows, bits 8, 9, and 10 (0-indexed) are important (i.e. if these are set = integer 448). See online Help for full details.
Hope this helps,
Khalid 🙂
___________________________
