How can I launch a desktop shortcut's VI with the right version of LabVIEW
I have applications that using either LV6i or 6.1. How can I launch a VI from desktop shortcut with the right LV version ?
(2,864 Views)
Hi KQD,
your LabVIEW installations are in different folders on you drive. LV 6i will install in "National Instruments\LabVIEW 6" and 6.1 in "National Instruments\LabVIEW 6.1". In your shortcut you give the command line "...\National Instruments\LabVIEW 6\labview.exe " resp. "...\National Instruments\LabVIEW 6.1\labview.exe ". This way the correct version of LabVIEW will be loaded and then your VI opened in LabVIEW.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,864 Views)
Hi HW,
I put "C:\Program Files\National Instruments\LabVIEW 6\LabVIEW.exe C:\PM Final\Check DVD.vi" in the the Target box and it gave me an error "Target is not valid". What did I do wrong ?
(2,864 Views)
You need to put quotes around paths with spaces. If the exe path and the VI path both have spaces, you need to enclose them in separate quotes.
"C:\Program Files\National Instruments\LabVIEW 6\LabVIEW.exe" "C:\PM Final\Check DVD.vi"
Include all quotes in your target.
(2,864 Views)
It works. Thank you very much, HW.
(2,864 Views)
