How can I keep running event-based state machine by a single event
Hello Folks,
I need your help.
In the event-based state machine when a Boolean is true then the event will occur but I want to keep my event running until Boolean (I’m using mechanical action “Switch when pressed”) is false.
Thanks.
- Reduanul
Message 1 of 23
(2,639 Views)
Could you attach your code? It sounds like you are running your code inside the event structure. I would recommend moving your code to its own loop and sending messages to start and stop based on the boolean events (you will get a value change event for both T-F and F-T).
Message 2 of 23
(2,625 Views)
Accepted by topic author REDUANUL
@REDUANUL wrote:
Hello Folks,
I need your help.
Thanks.
- Reduanul
I typically use the Value(Signaling) Property Node for this.
Here's an example of what I think you are asking...
I would probably put the Val(Sgnl) property node inside a case that follows your Boolean so it only triggers a value change when true.
=== Engineer Ambiguously ===
Message 3 of 23
(2,599 Views)
Please define "Keep the event running". Do you want to remain inside the event (not recommended) or re-enter the same event over and over as long as the boolean is true? What else needs to happen in parallel?
I sometimes use the timeout event for the bulk of the work and switch the timeout (held in a shift register) based on the new switch value between "short" and "-1" (i.e. infinite).
In any case, we need significantly more detail to give advice. Show us your VI.
Message 4 of 23
(2,588 Views)
@ RTSLVU,
Thanks for your advice but in my code, it's not working probably I have to do another way around.
@ altenbach,
Sorry for not being attaching the full code but for easy understanding please have a look:
Here when I press the ON/OFF button all messages are executed once but afterward Event Handing loop wait for another event from other cases or from the ON/OFF case.
So what I am trying is, when ON/OFF remained pressed messages will execute continuously instead of once. Then in the false case Event handling loop will wait for another event. Hope it helps you.
Message 5 of 23
(2,576 Views)
Use my timeout suggestion.
Message 6 of 23
(2,574 Views)
Here's how that could look like. (Assuming that your subVIs execute and return quickly, you can easily adapt it to your scenario.)
Message 7 of 23
(2,565 Views)
@ altenbach,
I tried your approach. I not getting where is the problem.
Here is my implementation:
I wired the timeout case according to your suggestion as well. Till now event handler only executing the message once to the Message handling loop.
Message 8 of 23
(2,552 Views)
No, that's just a picture.
Message 9 of 23
(2,545 Views)
And the picture doesn't even show all of the code. I don't think that you implemented the code the way altenbach suggested.
Message 10 of 23
(2,513 Views)
