How can I interface/Control an Android Phone from LabVIEW 2015
I am developing a test module where the ECU will make a voice call to an android phone and I would like to be able to monitor the voice call status (if it is in progress) and be able to hang up the call   from LabVIEW 2015. Since this is for automated testing, I need a method to be able to hang up the call to the phone which the ECU is dialing.
I want to connect, disconnect and monitor the status of the Voice call from LabVIEW 2015 application  .
Could anybody can suggest what is the best method for doing this ?  LabVIEW 2015  is running on Windows7 64bit desktop PC.
I am thiking about Bluetooth communication in LabVIEW 2015.
what all are the bluetooth dongle which will support LabVIEW 2015 and Windows7.
If anybody having command set or similar example for communicating with the Android Phone over Bluetooth or Serial kindly share with me.
Appreciate your help..
Jijith
Message 1 of 1
(4,395 Views)
