I'm after some tips on how to improve the response time to mouse clicks on a VI front panel.
I have data acquistion application which used to run fine, but after spending a couple of weeks making a whole bunch of changes to it I find that the user interface has become a bit sluggish.
My main GUI VI has a while loop running 16 times a second, updating some waveform charts and polling about a dozen buttons on the front panel.
There is sometimes a delay (variable, but up to 2 seconds sometimes) from when I click on a button to when it becomes depressed. I have wired the iteration terminal of the while loop to an indicator on the front panel and can see that the while loop is ticking over during the delayed response to the mouse click, so I know that the problem is not that the whole program is running slow, just the response to mouse clicks.
Also, just for debugging purposes, I have indicators of the iterations of all the main while loops in my program on the front panel, so I can see that there are no loops running abnormally fast either.
One thing I've tried is to turn off multi-threading, and this does seem to work - the response to mouse clicks is much faster. However, it has the side effect of making the main GUI while loop run less evenly. I was trying to get a fairly smooth waveform scrolling across the screen, and when multi-threading is off it gets a bit jerky.
Any other suggestion welcome..
(I am using LabVIEW 7.1, Windows 2000).
Mark.
