LVDSC supports the BMP and WMF file formats for images. If you can somehow convert your Autocad drawing into any of these formats, using them in your VIs is easy.
In the Tools>>Datalogging & Supervisory Control menu, you'll find an Image Navigator. This image navigator will allow you to import your images and copies them to Clipboard which you can later paste onto your front panels.
If you can't convert or 'save as' your Autocad drawing to a BMP/WMF format, as a last resort, you can take a screen dump (hit Alt+PrintScrn) and save it as either of these formats.
Hope this helps.
Rgds,
Khalid 🙂
