How can I get an array of variables in a formula?
I am trying to build a calculator using the Eval Multi-Variable Array.vi function. For this I need to get an array of variables present in the formula. Can someone give me a vi which will list all the variables present in the formula? Variable could be anything. The seperation between two variables will be the mathematical operator or brackets.
Cool Dude
(2,631 Views)
There are lot of function are there to do your work. example-Sarch and split string,Matchpattern,scan from string etc.....
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(2,612 Views)
Example VI
Balaji PK (CLA)
(2,610 Views)
