How can I get LabVIEW 7.1 to display the UTC time 03/11/2007 0230?
I have an application that uses UTC to time tag data.  I'd like to be able to display the correct UTC time in an indicator and along the x-axis of a waveform chart.
I've found that I can display any UTC time that's appropriate for local time.  I cannot display the UTC times that would not be found in local time.  (The hour between 3/11/2007 0200 and 3/11/2007 0259 for example.)
Is anyone aware of something I can do to display this time period correctly?
     Greg
P.S. I appreciate the improved behavior of the Seconds to Date/Time vi with respect to the DST flag (relative to LabVIEW version 6i).
Message 1 of 36
(7,455 Views)
Hello Greg,
Could you please attach an example that demonstrates the issue?
Thank you!
Kalin T.
Message 2 of 36
(7,412 Views)
Kalin,
Thanks for looking into this for me.  I have attached an example.
     Greg
Message 3 of 36
(7,400 Views)
I haven't tested this, but i've noticed that if you want to read time in UTC you have to use the %^T formatter instead of %T, so maybe that will work for you. Another option might be setting your computer to UTC time (not DST dependent)
Ton
My LabVIEW Ideas
Message 4 of 36
(7,392 Views)
Hi Greg,
I am still unable to see your problem. I ran your VI and everything seems fine to me. Not sure what you want me to look for. Switching between the different UTC times, it would just adjust to the local times - 4:00am, 5:00am, 6:00am.
Could you please clarify what I should be looking for?
Kalin T.
Message 5 of 36
(7,360 Views)
Kalin,
I apologize for the confusion.  I intended to show that I could not display the correct time (in UTC) for data acquired in the UTC time interval March 11, 2007 02:00 through 02:59.  LabVIEW seems determined only to display local times.  The problem is that I don't want to display local time.  I want to display UTC time.
In my example, the three switch positions should produce graphs with the left most label on the x-axis of March 11, 2007 01:00 UTC, March 11, 2007 02:00 UTC, and March 11, 2007 03:00 UTC respectively.  (The UTC seconds I use for the Xmin are 3600 second apart.)  What I see is March 11, 2007 01:00 UTC, March 11, 2007 03:00 UTC, and March 11, 2007 04:00 UTC respectively.  This is incorrect.
As you pointed out, the graph shows local times.  I cannot force it to display March 11,2007 02:00, a perfectly valid UTC time but invalid local time.
Anything I can do to change this?
     Greg
Message 6 of 36
(7,353 Views)
Hi Kalin,
      (i think) what Greg wanted you to see was:  when LabVIEW displays date-strings, it automatically adjusts for Daylight Savings Time.  On those days when DST changes, anomalies may appear in the sequence of times being displayed: displayed times jump forward from 1am to 3am at the moment DST comes into affect (and, I expect, "1am" appears twice where DST ends).  Greg wants to display times that don't include the DST offset - he's calling this time "UTC time".  Tonp seems to have a solution that's related to "format strings", but I don't know where "%^T" is to be used (in LV7.1) and Greg needs to format the date-strings appearing on the X-axis of a chart.  Tonp?
There's an Operating-system setting that can be changed so that when LabVIEW builds a date-string, DST is ignored.  I think Greg wants to design his software so that it will work as intended - without requiring an OS setting to be changed.
Cheers!
Message Edited by tbd on 03-27-2007 04:39 PM
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
Message 7 of 36
(7,345 Views)
tbd,
Well said!  Thanks for helping clarify things.
     Greg
P.S.   TonP, I haven't tried the format string you've suggested... but will very soon!  Thanks also.
Message 8 of 36
(7,340 Views)
TonP,
I tried your suggestion for the format string.  I still have the same problem: unable to display the time interval 03/11/2007 02:00 to 02:59.  Perhaps I've made a mistake implementing your suggestion.
     Greg
Message 9 of 36
(7,334 Views)
Kalin,
Please forgive me for using the acronym UTC without explanation.   From Wikipedia:
Coordinated Universal Time (UTC) is a high-precision atomic time standard. UTC has uniform seconds defined by International Atomic Time (TAI), with leap seconds announced at irregular intervals to compensate for the earth's slowing rotation and other discrepancies. Leap seconds allow UTC to closely track Universal Time (UT), a time standard based not on the uniform passage of seconds, but on Earth's angular rotation.
Time zones around the world are expressed as positive or negative offsets from UTC. As the zero-point reference, UTC is also referred to as Zulu time (Z). UTC is often referred to as Greenwich Mean Time when describing time zones, although strictly speaking, it is only an approximation.
It may not be obvious from this definition, but UTC does not change during daylight savings time.  For those of us in the Pacific NW, our local offset from UTC changes from -8 hours during standard time to -7 hours during daylight savings time.
We use UTC to time tag our data because it is continuous, lacking any of the discontinuities that occur at daylight savings time changes.  It is this continuous and unambiguous display that I want to show on the x-axis of my LabVIEW 7 graphs.
   Greg
Message 10 of 36
(7,318 Views)
