How can I get IMAQ ReadFile to read a folder of images?
So I did read a previous post on an error message of "IMAQ ReadFile access is denied." I think mine is the same one:
Error -1074395992 occurred at IMAQ ReadFile
  File access denied.
Possible reason(s):
IMAQ Vision:  (Hex 0xBFF604A8) File access denied.
Problem is that I still can't seem to figure out why I can't get the IMAQ ReadFile function to read the entire folder of images. I've attached my VI. My goal is to get the area of a certain part of the image (through thresholding) and export it to a text file, excel, etc in a table format. I will be taking about 1000 images/sec, so batch processing is...very needed.
For now, my VI just has it reading the image and outputing some statistics (which include the area) with the Particle Analysis Report function. I haven't figured out how to do the export into file - if anyone has insight in that, too, I'd appreciate it.
irealityworldi
Message 1 of 17
(8,847 Views)
Sorry to trouble anyone - I figured it out. Thanks!
-irealityworldi
Message 2 of 17
(8,829 Views)
I am having a similar problem with IMAQ read with tif images. Can you let me know please how you fixed it?
Thanks!
Message 3 of 17
(8,530 Views)
Hi femtovahan,
I greatly doubt he will post back since it has been so long (and a peek at his activity shows there hasn't been any in over a year).
Could you explain your current issue in more detail? Maybe one of us can help you out.
Jeff | LabVIEW Software Engineer
Message 4 of 17
(8,513 Views)
Jeff, thanks! Never mind, I fixed the problem.
Message 5 of 17
(8,510 Views)
Then please comment on how you fixed it.
If the original poster made the courtesy of posting his findings as well, perhaps you would have had your answer that much quicker. This way the next person can benefit from your knowledge.Smiley Wink
Message 6 of 17
(8,499 Views)
Right you areSmiley Happy
I am attaching a pic, if anyone has questions, let me know.
Message 7 of 17
(8,493 Views)
I have the same problem.. How could I fix it? I uploaded my code and 3 pic to use..
Yasemin Barutçu
Electrical And Electronics Engineer
Message 8 of 17
(7,712 Views)
Hey No_RegreTs,
I was not able to open your zip file...
A. Zaatari
Message 9 of 17
(7,704 Views)
I can open it. Would you please try to open it again using winrar? Maybe when you change its path ".rar", it may open. I'm not using my computer right now.
Yasemin Barutçu
Message 10 of 17
(7,698 Views)
