Altenbach, I think RedWolf wants the location of those elements.
In that case, you have 2 options.
You can build a function to search for all the elements of a 1D array and output them, then use a for loop to search each line of the array (example attached - 7.0),
or you can go over every element of the array by placing a for loop inside another for loop. Then, use the i terminals from both for loops to build your array.
In both cases, you will need to use a shift register on both loops in order to add only some of the elements to this array and use at least one i to determine where you are.
Edit: I actually remembered I already wrote a VI for this, so I'll attach it as well. Hell, I'll just throw in the entire polymorphic VI.
Another edit: Since you want 5 or larger, you will have to go over all the elements of the array, so this method, of using search array, will not help you.
Message Edited by tst on 05-04-2005 10:27 AM
___________________
Try to take over the world!
