取消
显示结果
搜索替代
您的意思是:
How can I find ETS operating system?
已解决!
转到解答
How can I get ETS? can I have a free version or trial one?
Regards!
0 项奖励
1 条消息(共 4 条)
3,121 次查看
Do you mean the LabVIEW realtime ETS or something else?
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
0 项奖励
2 条消息(共 4 条)
3,109 次查看
Hello, I would like to change my NI PXI 8106 controller into a real-time target, I am really confused I should installa a real-time operating system, or just formatting the hard disk as FAT32 file system and then booting it using floppy disk.
Best Regards!
0 项奖励
3 条消息(共 4 条)
3,077 次查看
解答
已被主题作者 Azzam87 接受
Hi Azzam87,
part of your question was answered in your parallel thread:
I have NI PXI 8106 controller (regular non RT), can I install Real Time operating system
http://forums.ni.com/ni/board/message?board.id=270&message.id=6825&requireLogin=False
You can try LV Realtime module for 30 day. Download this module, instal on host computer and after that install RT on PXI.
Follow this KB:
How Can I Make My PXI Controller a Real-time Target?
http://digital.ni.com/public.nsf/allkb/21C45EF391059C2A86257241005CA814?OpenDocument
Simply prepare your PXI. Convert to FAT32, after that create the USB boot flash disk in MAX.
Boot PXI from USB. Install the base of RT on PXI with this USB utility. After that boot PXI to RT and install the rest of software with MAX.
See:
PXI Installation/Configuration
http://www.ni.com/support/install/install_hardware_5.htm
Jiri Keprt
NIE Czech Republic
CLA, CTA
4 条消息(共 4 条)
3,050 次查看
