How can I display the front panel size?
    I am using the vi analyzer to make make sure that all of the front panels are the correct size. Is there a way to display the front panel size without having to run the VI analyzer?
Kaspar
(3,923 Views)
Accepted by topic author Kaspar
You could open the VI, go to File>>VI Properties>>Window Size>>Set to Current Panel Size, read out the Height and Width and then click Cancel.
Or you could do something like the following if you wanted to do it programmatically and just provide a file path to the VI you want to check:
(3,907 Views)
Property node for the VI for Front Panel Window Bounds ??
EDIT:  Just a couple minutes too late. But a slightly different property node.  You'll need to experiment to see which one works better for you.
(3,903 Views)
thanks for the reply!
Kaspar
(3,844 Views)
