annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
How can I display the actual AO voltage being outputed on a scaled channel?
How can I display the actual AO voltage being outputed by a PCI-6733 on one or more scaled channels?
(Note: Different channels may use different scales.)
0 Compliments
Message 1 sur 2
2 595 Visites
One sure way is to get a DMM and hook it to the output, then read the DMM programatically.  If you have several channels to monitor, you could use an AI and hook up the inputs to the AO outputs, then read each channel, or use a switch and switch the DMM to each channel.  That is the only way to know the actual output.  I don't think the AO has any self monitoring feature.
- tbob
Inventor of the WORM Global
0 Compliments
Message 2 sur 2
2 587 Visites
