To display time on the x axis, you can write to a couple of property nodes just like is done in the shipping example called Real-Time Chart. You could create a waveform data type and wire that to the chart. The difference would be to use a single waveform. For example, you could use a shift register and a build array function to create the Y array that you wire to a Build Waveform function. For this, you would not need to use a chart. A graph could be used.
