How can I display more than 1 loop iteraction in a waveform chart?
Using DAQmx, I am inputting a signal at a rate of 10k with 1k samples inside a while loop. I want the first 3 seconds of data to display on a waveform chart without having to change the rate or number of samples. Is there a way to stop the waveform chart from clearing after every loop iteration so that I can display more than 0.1sec of data? Thank you for any help you can provide!
(2,739 Views)
The default history length of a chart is 1024. To make it longer is a right click option.
(2,735 Views)
