How can I display an analog input to PXI-5105 out on LabVIEW?
Hi ALL,
I am very very new to LabVIEW and I just started to fiddle around with it. I am running LabVIEW 2010 SP1 version on Windows 7 OS. I also have NI PXIe-1073 chassis with PXIe-6361 and PXI-5105 modules and the chassis is connected to my PC via PCI. I was getting myself acquainted with the devices and was trying to see some analog signals to one of the channels on the PXI-5105 module in a graph in LabVIEW.
I would appreciate your helps.
(2,499 Views)
Accepted by topic author Henok
Hello Henokview!
I would like you to read through these tutorials to understand the programming steps of NI-SCOPE and NI-DAQmx. After reading these links below you will be able to understand how to connect output from a readfunction to a graph or chart.
DAQmx
https://www.ni.com/en/support/documentation/supplemental/06/getting-started-with-ni-daqmx--main-page...
NI-SCOPE
http://www.ni.com/white-paper/3382/en
Best regards
Jonas
Best regards
JM, LabVIEW CLA
(2,479 Views)
