How can I disable a shortcut in the LabVIEW development System?
I'm using LabVIEW with a swiss keyboard. However if I will use the # sign I have to press "als Gr"  +  #. But LabVIEW will always enable/disable the grid because this is also a grid shortcut...
Is there a way to disable the alt + #  function? Can I simply edit a "LabVIEW.rtm" file to disable this shortcut?
My current work aaround is to copy the sign from word into LabVIEW...
(2,665 Views)
Unfortunately the keyboard shortcuts are only editable in LV 8.0.
For a list of keyboard shortcuts in LV 7.x look at the following link:
In LV 8.0 you can edit the shortcuts in Tools->Options in the category Menu Shortcuts.
I hope it helps.
Best Regards,
Evrem Yarkin
NI Switzerland
(2,626 Views)
