How can I delimit my array to display in excel csv properly?
I currently have an array with 6 elements of type dbl inputs. I am trying to use the Write to Spreadsheet function to output this array to a csv file. Since it appears that the array has no spaces when output to the Write to Spreadsheet function, the output for each row looks as follows:
0.000.2310.2410.3310.5420.334
I need this to output into separate columns in the csv files like this:
0.00     0.231     0.241     0.331     0.542     0.334
What am I doing wrong?
(4,507 Views)
Accepted by topic author RWalker
Since you are writing to a CSV, Excel expects a comma to be the delimiter.  So make sure your delimiter is a comma (the default is a tab).
(4,498 Views)
Write to Spreadsheet file.VI has input Delimiter. Just connect there needed delimiter (space, tab, comma), and in the file data will be separated with proper delimiter.
Hopefully, it'll help you!
(4,494 Views)
Yeah, I don't understand why tab would be the default for a write to spreadsheet function, but that worked for me. Thanks.
(4,480 Views)
I've found that Excel doesn't quickly recognize CSV files (comma separated values) when commas are the separator even though that is the definition and in the name of the file type.  That often when you get a CSV file into Excel, you need to go through the dialog boxes and check off that the comma is a separator.
If you use tab in the files, Excel separates values on that with out any extra steps.
(4,451 Views)
In my experience, that only works if you use a TXT extension.  CSVs have always directly loaded for me in Excel without that dialog.
(4,444 Views)
You are probably right.
I never save a file with an actual .CSV extension.  If it is readable to me, I call it .txt.
I don't understand why Excel doesn't have an option to also have the comma be recognized as a delimter.  It has always annoyed me that I need to go through the dialogs to click that box, or use Text To columns to break up that data.
(4,402 Views)
