How can I create software start and stop trigger in LabView using 6023E series DAQ card? I don't want to use the external trigger.
I am using 6023E DAQ card to collect the signals, such as AE, Force, Torque from the machine. I want to collect only some part of signal for example between start triger and stop trigger. I'd like to know how I can creat those triggers in LabView from one of the channels that I am acquiring at the same time. I found one or two library file that is only for start trigger. I know that this is availabe in some of DIAdem functions. Please let me know if you have done some example for this requirement.
(3,199 Views)
If you are wanting to create a software trigger based on an analog input voltage in LabVIEW, there are several options. One suggestion would be to compare the voltage values from one input channel to a number within a loop. If the input voltage crosses that threshold (is greater than the number), have a case statement that will acquire data from the other channels. This would simulate a software start trigger in LabVIEW.
(3,199 Views)
