How can I create an XY graph displaying live data from multiple sensors in a project
I need the flexibility to select one sensor for the X-axis and choose multiple sensors for the Y-axis. What approach should I take to input and organize the data effectively for generating plots in this scenario?".Now the issue is I am not getting the proper logic of how to pass this live data to generate the multiple plots in the XY graph.
(1,488 Views)
Typically, you would build the data up in a shift register.
Maybe you could attach a simplified example of what you have so far so we can form a better picture of the problem..
(1,480 Views)
We have attached the vi here,can you pls go through it.There is a subvi inside which the xy graph logic (till now) has been done.
(1,463 Views)
I can't currently look at your VI because the version is too new. Please "save for previous", (LabVIEW 2020 or below) and attach again.
(1,399 Views)
