How can I create a multiple value slide indicator
I need to plot an indicator which has to have three values: one actual value of the parameter, one bar for alert value and one bar for danger value, all in the same slide indicator.
In other words, what I need is to insert in the slide indicator a cluster of three numeric values, not just one.
Any help will be appreciated.
Greetings, CJMV
(3,500 Views)
Right click on the slider and choose "Add Slider" as many times as you want.
Hope this helps,
Paulo
(3,494 Views)
i´ve attached an example for you. You can add bars in your slide indicator if you change the properties of your indicator -> appearance -> add.
Hope it helps
(3,486 Views)
thank you very much PauloM and Indiana, the solution was simple and just what i need
greetings
CJMV
(3,477 Views)
