How can I create a combo box/enum with sub categories
when creating a combo box in LabVIEW I can edit the items to obtain several options. I would like to have have several sub-Options as depicted below.
How is this possible in LabVIEW?
Best
(4,390 Views)
Hi volfi,
in your image you show a menu: you can create them with LabVIEW too, either static or programmatically using the menu functions.
You could also use a tree control to create such a "tree" of items…
(4,370 Views)
Hi GerdW,
thanks for your reply! Yes I am looking for something like the menu functions but I want to place it anywhere on the front Panel, not only the menu bar in the upper left Corner. Thanks!
(4,361 Views)
Hi volfi,
you could create (or "fake") this behaviour by opening some subVIs for each subtree…
(4,355 Views)
Can't you create a r-click menu with sublevel for a button?
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,326 Views)
Make a button (or something) on the FP.
Tie the Left-click mouse-down event to an event that handles that button's shortcut menu.  It's a little hacky, but it largely does what you're looking for.
(4,314 Views)
It's not hacky; this is exactly what "filter" events like "Mouse Down?" exist for.  Here's a similar example: a menu button on a graph.
(4,300 Views)
