How can I create a Report with LabView Real-Time?
With conventional LabView, I can create Reports in HTML, for example to document Errors.
I need this feature in LabView Realtime. Is it possible?
(3,293 Views)
I have Labview RT and can confirm that it, like the non-RT version, has the same Report Generation tools. In fact, LV-RT has all the same tools and more (for the RT controls), so you would be fully set with the RT version.
Doug
(3,293 Views)
It is possible, but you got to put a name to the file with an extension of three letters. i.e. errors.htm
Three letters on the extension is what the RT Operating system allows to use.
Then you will need to do an ftp to your RT machine and get the file and maybe change the extensions.
Not all the vis for Report generation can be used in the RT engine. The ones that use ACTIVE X will not work. i.e printting
Another way to generate reports and the most recommended is to use the host machine to generate the reports.
Blasioz Valenzuela
(3,293 Views)
