How can I copy a string to windows clipboard programmatically?
knows anybody a way to copy a string from VI to the Windows Clipboard? The LV Helpfile supports nothing and in "lvwutils" I can't find a function therefore.
I use LV 7.1 and Windows 2000.
Thanks for any help
Christian
Christian
Test Engineering
digades GmbH
www.digades.com
Message 1 of 19
(9,648 Views)
hi there
well, there are several solutions. i attached the condensed version of a ActiveX-DLL written in VB 6.0 and a VI that calls it. you may have to first browse to the DLL in the Automation RefNum.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 2 of 19
(9,642 Views)
... sorry, here it is...
Best regards
chris
Message 3 of 19
(9,639 Views)
If you want a built in windows solution, have a look at these VIs, which use standard windows API functions.
___________________
Try to take over the world!
Message 4 of 19
(9,618 Views)
Thanks ....It is helpfull for me.
Message 5 of 19
(8,640 Views)
In the meantime since that old thread started about 10 years ago LabVIEW has gotten official support in the VI Server interface.
This is a snippet! Drag it to your desktop and from there into a LabVIEW diagram. It will work on other platforms than Windows 32 Bit too, unlike the clibboard.llb library.
Rolf Kalbermatter  My Blog
Message 6 of 19
(8,631 Views)
wow ....it is really appericatable your fast reply and nature to help.. Thanks a ton.
Message 7 of 19
(8,622 Views)
I had no idea you could drop and drag snippets! I thought snippets were PNG's! Changed my life, now just need to claim back the many dozens of hours I've spent copying snippets by hand........
Message 8 of 19
(8,344 Views)
By the way, I think rolfk's post is a bit outdated. You can drag the snippet directly from your browser to your block diagram usually without needing to save it to file first.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 9 of 19
(8,332 Views)
Nope. Does not work with Firefox in this way, first i have to save the png. However, the simple drag&drop works with Chrome browser... No idea why is this difference.
Message 10 of 19
(8,324 Views)
