How can I convert a string of hex values to a hex format string programatically?
Thank you!
Message 11 of 21
(1,675 Views)
Nice solution Darin.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 21
(1,673 Views)
OK, I had a thought this morning when I was one the road to work. I was impressed with Darin's suggestion and got to thinking about it. Now, for the teaching moment. One of the suggestions with a minor modification would be much more efficient if the input data was a large buffer. So, which one is more memory effiicient and why? Also, what would the modification be?
Mark Yedinak
LabVIEW Champion
Message 13 of 21
(1,645 Views)
Mark,
With your original VI it doesn't seem to work when the input string is 484 characters long. If I cut that in about half it works fine. Any idea why?
Thank you,
Chuck M.
Message 14 of 21
(1,639 Views)
More specifically, after 256 characters, the output string, repeats itself.
Message 15 of 21
(1,635 Views)
Post your code. It works fine with long strings. I just tested a 1024 byte string with no issues.
Message Edited by Mark Yedinak on 03-19-2010 12:05 PM
Mark Yedinak
LabVIEW Champion
Message 16 of 21
(1,626 Views)
My guess is that you have your index set to be a U8 integer rather than a U32 or I32 and it is rolling over when you increment it past 255.
Message 17 of 21
(1,620 Views)
Yes, exactly, I just discovered that a few minutes ago.
Thank you,
Message 18 of 21
(1,618 Views)
I changed the initialization of the for loop from U8 to U16 and it works great
Message 19 of 21
(1,616 Views)
Do you have LabVIEW 2009?  If so, Mark's screenshot was a VI snippet.  You could drag and drop that image from the browser to the block diagram, and you'd have the code.
Message 20 of 21
(1,614 Views)
