How can I configure again the LabVIEW software? what do I need to do?
We have trouble by calibrating the NI-DAQ board via software, by using the library configuration and calibration, we think the software is misconfigured because it does not save the calibration we do trhough a control named Calibrate_1200, hos can we configure the LabVIEW again?
(2,629 Views)
If you're planning to configure the DAQ card, you might want to start from Measurement and Automation Explorer (MAX).
You should be able to configure the hardware that way. The configuration is then accessible in LabVIEW.
Shan Pin Koh
(2,629 Views)
