07-14-2009 01:29 PM
Solved! Go to Solution.
07-14-2009 01:41 PM
07-14-2009 01:46 PM - edited 07-14-2009 01:47 PM
07-14-2009 01:46 PM
07-14-2009 02:03 PM
07-14-2009 02:21 PM
Use a table indicator and then color the cells according to your needs.
(You cannot change the property of individual array elements anyway. Properties are global for all elements in an array)
07-14-2009 02:29 PM
07-14-2009 02:29 PM - edited 07-14-2009 02:31 PM
Yeah, altenbach's suggestion is the best. I wrote my example before I saw the array spec.
Edit: Dang, beat again.
07-14-2009 05:27 PM
Here is an old example that show some of the basic methods how you could change the font color depending on the cell contents (testset2MOD.zip).
