Check out the TCP/IP examples that ship with LabVIEW. That should get you started. If your devices work via telnet or hyperterminal, the TCP/IP VIs should handle them well. If those devices are instruments, they may even have LabVIEW drivers already written.
Daniel L. Press
PrimeTest Corp.
www.primetest.com
