How can I check that all numbers in a serial number are numeric
I wrote a vi that checks to make sure that a serial number is in the "mmddyy-xxx" format, where xxx can be from 0 to 999. The problem is if I enter something like "012210-A1" it passes. Is there an easy fix to fail anything where xxx is not in the 0 to 999 range?
Thank you
(3,508 Views)
Accepted by topic author chuck72352
You could use the Lexical Class function. If the character is a digit between 0 and 9, it returns a class number of 3.
(3,504 Views)
Please check the link below:
http://forums.ni.com/ni/board/message?board.id=170&message.id=370717&requireLogin=False
Is this what you need?
Thanks.
Best Regards
Luciano Borges
Test Development Engineer
(3,498 Views)
Hi chuck,
you can do it that way:
When the serial number isn't correct you will get an error from the ScanFromString function...
(3,489 Views)
