How can I check/query whether a file is in use/locked by another program?
My data acqusition system writes data files that some users would like to inspect while the acquisition is still running. I periodically write to the file and then close the files afterwards. However, if the user opens the data file in e.g. Excel, the file is locked. This is not a problem, in the sense that I can just postpone the commitment of data to the disk, but instead of getting an error message, I would like to be able to check whether the file is locked before attempting to write it.
(3,221 Views)
Getting the error should be pretty quick when you attempt to write. I mention this because there should be no performace problems with using the code you already have. Instead, I think you should condisider ancy error handling. Right after file open you can unbundle the error cluster and inspect the error code. This error code can then be sent to a case struture for conditional logic. Remember you can always rebundle the error cluster with any data you want after you have trapped the file lock error.
(3,221 Views)
Another option you may want to consider. You can require the user to open the data file as Read-Only. If the user opens Excel, browses for the file and chooses Open as Read Only, the problem is eliminated.
What I like to do is include a button on the front panel that will open the data file for them, allowing me to force it to be read only. There are two easy ways to do this:
1. Elegant: ActiveX. Open Excel.app, make visible, workbooks.open with read only true. Close all references.
2. Quick: SystemExec. Call the command line >Excel.exe d:\Data\flowdata.xls /r
Michael
www.abcdefirm.com
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
(3,221 Views)
