How can I change the text label look of a (silver) dial?
Ah Jeff, now I see. I just looked at the pictures, didn't pay enough attention to the description. My bad!
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 11 of 14
(597 Views)
Just an update: I managed to create a custom control. The colours of the enum behave a bit strangely  (they seem to change without any particular reason), but it appears to be the neatest workaround so far. (file attached)
Message 12 of 14
(571 Views)
OK how did you accomplish the replacement? (Nicely worked out!)
Noted issues remain:
Digital display of the text display is still "Modern"
Turning text values off and on again reverts to a "Modern" text display
"Should be" isn't "Is" -Jay
Message 13 of 14
(565 Views)
While I was in Customize Mode I clicked on the text display and went to Edit > Customize Control. Afterwards I was able to replace the text with a proper -silver style- enum. As you pointed out it is anything but perfect, though I find it more convenient than messing with the Event Structure.
Message 14 of 14
(553 Views)
