How can I build a table with the time values of a timer from a while loop
The reserved error implies that you are trying to access the analog input channels on the device while another analog input task is running
With multiplexed data acquisition boards (E-Series and M-Series), only one analog input and one analog output task can be run at the same time. This is the case because all analog input channels require use of the same channel multiplexer and sample clock. Thus, in order to perform multiple channel acquisition, all channels must be included in the same task.
Read this link
Hope this helps
Message Edited by devchander on 05-22-2007 05:32 AM
Message 21 of 21
(446 Views)
