How can I build a multi instance application?
How can build an application (exe file) that can be running in multiple instances (like notepad)?
I select the vi properties.execution.reentrancy.preallocated clone reentrant execution but after building the application, the exe file can be run only into one instance. Double-clicking on the exe file for second time don't open a new instance.
(3,037 Views)
Accepted by topic author Marinica
If you add the line allowmultipleinstances=true to the EXE's INI file under the application's section, every call to the EXE will create a new instance. Note that if you use shared resources (hardware, files, etc.), you will have to account for that.
___________________
Try to take over the world!
(3,016 Views)
It works!
Thank you.
(3,001 Views)
