How can I assign filename for the Write Table to XL.vi from NI sample?
The sample from NI (Write Table to XL.vi) works fine, but always it open a "Book1" as defult then askes to save it later!
I try to modify it and assign a meaningfull filename so that the user does need to save or rename it ... but I failed!
Is there an easy way to modify this sample for that purpose? Can anyone help me?
Thanks.
(2,958 Views)
Hi ATC,
I modified your vi, it creates an XLS file with the filename you assign (no dialog box).
You get a dialog box only if the file already exists, but this is normal; if you don't want to have it either, simply delete it progammatically before creating the new one.
Good luck,
Alberto
(2,958 Views)
Hi Alberto,
Thank for the modification, it works as I like it ... you helps me save a lot of times (I did try like it before, but I forget to change the Excel control ... and the "Book1" appears always confused me and that was why I thought my assigned filename did not affected at all!).
With your comments that actually makes my applications working very well now.
Thanks a lot and regards
(2,958 Views)
