How can I add the number of columns/row starting with the build in "Text Report" example in the LabVIEW
Hi All,
I am wondering how can I add the numbers of row and column from the existing build-in "text report"
VI ? If possible, would you mind showing me step-by-step because I am a new user and I am not familiar with the labview software.
(2,857 Views)
Hi 111284,
can you explain a bit more? Do you mean the "Easy text report" vi?
Mike
(2,854 Views)
Easy text Report is for saving to a file. Do you mean you just want to add the totals of two arrays and write that? In that case I would just append the totals before writing to file.
Jeff | LabVIEW Software Engineer
(2,835 Views)
