How can I acquire two signals from two different channels at the same time?
I want to aquire two signals from two different channels (torque and angle). It works with one channel , but it doesn't when i add one... What i'm doing wrong?
 What's the difference between connector number and channel number? Thank you in advance! (I'm begginer in Labview)
(2,695 Views)
Hi sda,
it seems you use HBM hardware and driver for that hardware.
If your question is related to that hardware and software you need to ask HBM to help you with their software! Maybe they already gave you a manual?
(2,692 Views)
