How can I acess my VI runing in my PC in my office in The internet any Where I want
I have an intranet with acess to the internet,No web server.How Can I acess my VI runing in my office in my house through the internet.
Thanks.
Certified LabVIEW Architect
Certified TestStand Architect
(3,105 Views)
Hi
You have to use the "Web publishing tool"
Located in your "Tolls" menu on the front panel.
If you don't see it, you might need to buy it from NI
Doc-Doc
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(3,105 Views)
Thanks Doc-Doc, It only works in my lokal network but not on the internet ,I need the internet toolkit from NI.
Ohiofudu
(3,105 Views)
You don't need the internet toolkit, this is for something entirely different.
If it works in the local network, it will work from everywhere. However, you might have one of the following problems:
-- Check your browser access options in LabVIEW. Do you only allow access from the local subnet?
-- Do you have a public IP or is your intranet behind NAT? If it is behind M-1 NAT (One public IP shared by several private IPs) you need to forward the correct port to the private LAN IP of your PC. This is done in the router configuration. From the outside, you later need to access the public IP of your router to get to your PC.
-- Is there a coporate firewall that prevents incoming connections?
-- Do you run personal firewall software (Zonealarm, Sygate persona
l firewall, Kerio, etc.). These need to be configured with policies to allow access.
(3,105 Views)
Hi altenbach,Thanks it works just as you said.Thanks
my boss is pleased.But it is not working on my linux suse system any tipp????
(3,105 Views)
I could not get my vi on my linux system using konqueror as my web browser .I have Failed inintializing Labview plug-in client error.I have labview plugin installed in my system.is there any help you can give me.
ohiofudu.
(3,105 Views)
