How can I Unblock VIs Internally blocked by LabView 7.1 Source Control Code ?
I try to use Source Control Code for the first time, I save a project from a Main Top level VI.
But because My project contains some VIs in LLB SCC report problem to stores them into DataBase,
And now I cannot edit these VI ?
How can I Do to cancel totally the use of SCC ?
(2,628 Views)
The SCC tool is very interesting but indeed I would never recommend using SCC and LLBs together. It would be the same thing as storing your C application in a few zip files and checking them in and out.
Once your project is created, you can access SCC functionality for your VI such as “Add to SCC”, “Remove from SCC”, “Check Out”, “Check In”, etc. from the Tools->Source Code Control menu.
Now to edit your VIs, go to "Tools>>SCC>>Check Out..."
Please see the document in the link below :
http://digital.ni.com/manuals.nsf/webAdvsearch/5FBA64AD223A76A786256D2C00561F2D?OpenDocument&vid=niwc&node=132100_US
Hope this help.
Best Regards,
Sanaa T
National Instruments France
Sanaa T.
(2,592 Views)
