How can I Manually Insert an Image into a Picture Control?
        I am able to insert an image programmatically into a picture control. But I want to insert an image into the picture control without any code that is manually. How can I Do that?
Thanks in Advance
Regars,
Malleswari
(3,379 Views)
So your Subject says "how can I manually insert a picture in a picture control?" and your post says " how can i programmatically insert a ...."
manually: drag it from explorer to the picture control or copy and paste it
programmatically: "Read jpg.vi" + "Draw flattend pixmap.vi"
(3,377 Views)
Thanks in Advance
Regars,
Malleswari
You may also drag and drop a picture directly to your front panel. You can also use paint, or some other tools,  to copy a part of a picture and past it into your front panel. This actually works for the block diagram also. Se example
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,359 Views)
