How best to insert a sub-array (row) into a 2D array at the correct index which is depending on the value of the first column
I'm sorry, would it be possible to modify the attached? sorry, I don't quite get it.
Kas
Message 11 of 22
(2,176 Views)
I went through your suggestion, but I still couldn't do it. However, I managed to get half of it working.
I now can rearrange and place the data where they should be based on "row", but I still can't rearrange it based on the "Column".
Attached is modified version.
Kas
Message 12 of 22
(2,156 Views)
I went through the suggestion again and payed little more attention. It worked just as you said. Thanks again for your replies.
Just incase, attached is the working example for anyone else reading this thread.
Kas
Message 13 of 22
(2,140 Views)
Hi Kas,
it wasn't that hard to get your program running? Smiley Wink
Well, I did some "enhancements" to your VI... No need for the first FOR loop!
Message 14 of 22
(2,125 Views)
Hi I have a  similar question for this topic,
I will like to insert data in a row by "n" times given on first column.
The data to be inserted corresponds to the data where the "n" number is located
Here's an example of my 2D array:
3   0 0 0 1
1   1 1 1 0
2   0 0 1 1
To:
0 0 0 1
0 0 0 1
0 0 0 1
1 1 1 0
It doesn't matter if column 0 is also inserted i can delete after.
Thanks a lot in advance.
R
Message 15 of 22
(1,987 Views)
I don't get it. are you saying that because you have a "3" in the first column, you are now insterting 3 rows of the same element afterwords?
i.e.
3   0 0 0 1
1   1 1 1 0
2   0 0 1 1
to:
0 0 0 1
0 0 0 1
0 0 0 1
0 0 0 1
1 1 1 0
0 0 1 1
Message 16 of 22
(1,983 Views)
Yes, that's exactly right. The first column is given to me and as you pointed out it determines how many times the same element is repeated afterwords.
Message 17 of 22
(1,973 Views)
It looks like this could work, I'll give it a try...Thanks a lot!
Message 19 of 22
(1,961 Views)
Hi, it gave me some idea on how to approach it, in my case the elements are string. Here's a snapshot of what i'm looking for would look like:
Thanks!
Message 20 of 22
(1,951 Views)
