How To Sync Timing of Encoder and Load Cell
I have a code where I need to synchronize the timing of two different sensors (one analog and one counter), but I'm not fully certain on how to achieve this. I tried using the trigger that was used for the analog inputs, however it said that it wasn't supported when I implemented it into the encoder code. Any thoughts or ideas would be appreciated.
(1,130 Views)
Yeah, counters are a bit of an "odd duck" in that counter *input* tasks can't use a regular ol' Start trigger.  Instead, they can only use a special, harder-to-find "Arm Start" trigger.
But in any event, I'd recommend that you use a shared sample clock to sync the tasks.  Configure the counter task to use the AI task's sample clock "/Dev1/ai/SampleClock" and use dataflow sequencing to make sure the counter task is started before the AI task.
Here's an incomplete example I once posted showing how to do that part of the configuration.
-Kevin P
(1,105 Views)
Thank you for the response! I do have one question. Would this also stop them at the same time? I need it to stop reading shortly after the encoder collects data so that it can be exported to excel and compared with the load cell data.
(1,092 Views)
Also, is this what you meant by configuring the counter to the ai/sampleclock?
(1,090 Views)
