How To Fix NUMBER in Matrix array (LABVIEW 2011)
If I want the values ​​in the matrix array to store the values ​​entered. It was close and then open a new value is retained. I have to do. I need my fix.
Message 1 of 8
(4,254 Views)
Well, not to be too obvious, if you want the values stored, you have to store them some where. How do you want to save them? Text File, Excel, Database, other? You don't give us nearly enough information for us to give you an answer.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(4,251 Views)
well, I usually start by LAbview. Numeric control must always specify a new value. But what I want is. I value the time that it is the same when I close the program LABVIEW.
Message 3 of 8
(4,247 Views)
Ok, I get that, but how do you want to save the data?
Mike...
LabVIEW Champion
Message 4 of 8
(4,245 Views)
yes, plaese to help me plaese
Message 5 of 8
(4,241 Views)
I think what's he's saying is that he wants the values to be stored as the control's defaults.
ToNTi, for each control or indicator where you want to save values (so that next time you open the VI in LabVIEW, those values will be stored in the control), right-click it, choose Data Operations»Make Current Value Default. If you want to do this for all controls and indicators at the same time, go to the Edit menu and choose Make Current Values Default. You will need to do this before you close the VI, whenever you have new values that you want to save.
There is an invoke node that can do the same thing, but it can't be used on a VI that's runnning, so it probably won't help you.
Message 6 of 8
(4,238 Views)
Tonti, the translator isn't helping you, really...
maybe post in your native language forum, quizás la comunidad en español? http://forums.ni.com/t5/La-Comunidad-en-Espa%C3%B1ol/ct-p/ESAForum
Message 7 of 8
(4,232 Views)
thank you I can do it
Message 8 of 8
(4,230 Views)
