How To Fix LabView Myrio Code
I'm still a beginner with labview, can you help me with logic like that in the case structure
(1,268 Views)
What help do you need? Please be specific about the issue you encounter.
Please upload your code. We cannot debug or edit images.
https://tmesystems.net/
(1,243 Views)
There is nothing wrong with the case structures, it's all abut the contents! And so far we can't see any "logic" anywhere. In the visible case you are trying to wire an array to a scalar indicator (thus the broken wires). We cannot comment on stuff we cannot see, so please attach your VI.
  • Make sure all controls have reasonable default values
  • Save for previous (2020 or below) if you use a newer LabVIEW version
  • Explain in detail what the code is supposed to do, how you intend to use it (operate controls in what order, etc.) and what you expect to happen.
(1,217 Views)
If you are a beginner in LabVIEW, you should learn "regular LabVIEW" before you attempt the complexities of "Real-Time LabVIEW".
(1,197 Views)
