How To ADD Child inside the childe in XML File
I want to write setting file using XML toolkit.
 in that I am facing proble to add child in side the child.
Please Guide me to resilve this problem.
Prabhakant Patil
Regards
Prabhakant Patil
Message 1 of 9
(6,173 Views)
I think first you have to create a new element using the respective Invoke node (XML) and then you can add it using Invoke node "add child".
Message 2 of 9
(6,171 Views)
I tried the Same Thing.
 I can Add Number of Child inside the element. but nit able to Add child in side the Child.
Prabhakant Patil
Regards
Prabhakant Patil
Message 3 of 9
(6,168 Views)
How it is possible
Regards
Prabhakant Patil
Message 4 of 9
(6,160 Views)
please have look at the example
Message 5 of 9
(6,148 Views)
Hi
I allready Done this thing.
I want Add child in the Secon Element and again I have to create New Tag in the Same File.
Regards
Prabhakant Patil
Message 6 of 9
(6,139 Views)
Perhaps it would be also helpfull if you post your code.
Message 7 of 9
(6,137 Views)
Accepted by topic author Prabhakant_Patil
I its a good Solution. Now I am trying to Add new Tag and Again in that new Child.
Prabhakant Patil
Regards
Prabhakant Patil
Message 8 of 9
(6,133 Views)
Then please mark Jorn's post as the solution to your problem to give him proper credit rather then your own thank you message.  If you go to the options menu to the upper right of your message first, you will be able to unmark it as the solution.
Message 9 of 9
(5,863 Views)
