How Print Screen pragmatically?
Hi Samuel,
can you explain why the print screen with the simulated keyboard event isn't a solution for you?
Mike
Message 11 of 25
(1,768 Views)
Just to know. Actually i dont want to capture the whole screen i want just a portion of a screen.
Message 12 of 25
(1,766 Views)
Hi Samuel,
how do you define the portion of the screen? You can simulate Alt+print for only the active window. 🙂
Mike
Message Edited by MikeS81 on 07-09-2009 04:30 PM
Message 13 of 25
(1,764 Views)
I want to capture a portion of screen which surrounds the mouse pointer.
Message 14 of 25
(1,736 Views)
Do you exactly mean the other way round... ?! Smiley Very Happy
Portion of the screen surrounded (marked) by the mouse pointer... Smiley Wink
- Partha ( CLD until Oct 2027 🙂 )
Message 15 of 25
(1,732 Views)
Cant u do the print screen as suggested by mike and then extract the required portion?
Message 16 of 25
(1,727 Views)
Hi samuel,
you can use this and change it to what you see in the attached image to get what you want.
Mike
Message 17 of 25
(1,720 Views)
Mike, that was useful. Thanks
Message 18 of 25
(1,688 Views)
Its really very usefull,I already added this to my VI library thanks mike.
Message Edited by Baji on 07-13-2009 03:07 PM
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 19 of 25
(1,680 Views)
Hi Baji,
Why you remove your example VI... ?!
Message 20 of 25
(1,670 Views)
