How I get the 68881/68882 floating point emulator?
I already installed LabView 4.01 Full devepment system over a macintosh Power PC 6100/60, it's using Mac Os. 7.5.
I can't run LabView, because there appears a error message that says "LabView is built to run on a Mac at Motorola 680x0 processors. It can be run on a power Macintosh but requires software 68881/68882 floating point emulator".
So my question is how I get the floating point emulator?
(3,080 Views)
The emulator you are looking for will have
to be retreived from Apple. It is a piece of
software that fools programs into believeing
you have harware that is not present in your system. I am no Mac guru so this is all I can tell you.
I will warn you however that you are using a very outdated version of Labview (the latest is 6.0.2).
Kevin Kent
(3,080 Views)
