> If you mean 'property nodes' or similar, simply right click on one of
> the elements to change it. There is no direct way to move them, so if
> you want the bottom one moved to the top you will have to modify all
> elements...
Actually, it is easier to duplicate a new element by popping up on a terminal
at the top and selecting Add Element. Then change the new element to select
the same property as on the bottom. Rewire and delete the bottom element.
At least then you don't have to touch any inbetween.
Greg McKaskle
