How I can get "value change" event if I have a XControl with both indicators and control?
Hi All,
I'm using LV 8.5.1. My problem is followed: I have created a Xcontrol which is compound of few  indicators and controls. On my code XControl act always as indicator and I read control values by using my own created properties. I need to launch a new event when user change some of the control values. At this moment event structure can't detect these changes. Is this a property or a bug ?
BR,
(2,966 Views)
Hi BR,
You should change your XControl on the owning VI into a control.
Inside the XControl you can have both controls and indicators.
This will give your user the possibility to change one of them.
Note that you have to make additional event cases inside your XControl for those controls.
Ton
My LabVIEW Ideas
(2,946 Views)
Hi Ton,
Thanks for your hints. I made a small test and found quite strange behavior of my XControl. I added one ring, boolean, and enum control to my XControl (see attachment) and added "value change" events inside the XControl. I added "one button dialog" VI to those events to recognize if event is fired. When I  change value of ring or enum (items 1,3,4) sometimes  pop-up shows up  and sometimes not but when I change value of boolean it always fires a event.
So my Xcontrol and main VI fires event always only when I change boolean value. Do you have any suggestion how to proceed? At this moment I can't send whole code here 😞
(2,916 Views)
I can't find a valid reason for this. Try to replace the message with just a plain string indicator inside your XControl, that might help.
Ton
My LabVIEW Ideas
(2,900 Views)
