How Do I use HP82350A(GPIBcard PCI) wiht LabVIWE 6i?
I Can't use HP82350A(GPIBcard PCI) wiht LabVIWE6i, Plaese tell me to installaion Guide.
(2,662 Views)
Hi Somsak,
The first thing to do when installing a new peripheral device, such as a GPIB card (including those from NI), is to register them using Measurement & Automation Explorer (MAX).
Steps:
1. Install the hardware as per manufacturer's recommendation. Also install the sw driver.
2. Open MAX.
3. Under "My System".
4. Browse under "Devices and Interfaces".
5. You should see GPIB0.
6. Right-click on the GPIB0 and select "Scan for Instrument".
7. If you have any instruments, they will appear in the window on the right.
-JLV-
(2,662 Views)
Are you using VISA or the GPIB/488 functions? If you're using VISA, then after installing the VISA driver from Agilent, then you shouldn't have any problems. The installation guide should be available from Agilent. Have you tried their web site?
(2,662 Views)
