How Do I get the Basic Function Generator to generate more than a second's worth of waveforms?
Ufgul1n
Hi I'd like to ask whether it's possible to get my Basic Function Generator to generate more than a second's worth of waveform.
The upper waveform graph shows the output from the BFG block, while the waveform chart shows a  resultant output. The current setup works well enough with I just stick to whole numbers for frequencies, but once I go into the decimals the output waveform becomes discontinuous e.g. 'ripples' in sine waves.
This is my VI:
2KC110D
Many thanks for the assistance!
(2,558 Views)
Hi Baba,
Then answer to your quesion is "Yes!"…
Did you read the help for the BasicFunctionGenerator? Did you learn about all its input parameters?
Did you learn about the sampling info parameter?
Do you know the relation of Fs and #s?
This is my VI
No, this is not your VI. It's just an image of the block diagram of your VI…
Btw. why don't you use a simple queue to transfer data between loops?
(2,554 Views)
